car won't start - any ideas?
aznriceracr
Nov 15, 2003
San Diego, California
Hey, I am having a problem with my car. I dropped in a new engine into it with the help of my friend. Everything is wired up, all the hoses are on. I changed the injectors, the guy I bought the car from said the ECU was fine, but my car isn't starting up. It turns over fine and it sounds real strong, I have spark, and I have fuel, but it still won't kick over. Does anyone have any ideas?
thanks
-Ben
Spark plug wires on proper cylinders? Spark timing incorrect? Timing belt broken or on wrong notch? Non-turbo ECU on a turbo engine (vice-versa)? Fuel actually getting into cylinders (pull plugs and see if wet or dry)?
Where is the crank angle and cam angle sensor in my 1g? how do i check them to see if they're good?
-Ben
Before you get into the angle sensors (which rarely fail unless the connector isn't making contact), make sure you REALLY ARE getting enough spark and fuel where it counts. Pull each plug, hold against the engine with the wire on, crank over and make sure the spark is adequate. Make sure fuel is making it into the cylinders. Do you smell gas? Are the spark plugs wet (or get wet when their wire is disconnected)? Check fuel pressure if you have a gauge (should be between 33 and 50 psi depending on engine).
Does the engine fire at all?
If your convinced about the spark and fuel, I would next check the spark timing with a timing light. If the sensors are bad or the shafts aren't lined up correctly, the timing will be way off.
Next test the compressions of the cylinders.
  • For sale 4G63 MHI 20G Turbo ( Zero Miles, built by JW )
    MHI 20G Turbo $700 + shipping and paypal fees* built by Justin Whitesell * ZERO miles since...
  • For sale 2g 2G DSM Link V3
    2G DSM Link V3 $595 + shipping and paypal fees* no cable includedYou must be registered to...
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
