car wont start again.. =/
danielsl1999gsx
847
93
Jun 5, 2009
los angles, California
Well here it comes again, the good old cranks. I have just recently install a good some of parts in my car because it wasthe right time too. So today i finish installing everything and gave try to start her up. She turn over and start to stutter like almost turning on but then she gave up.Now all she will do is crank over. im a bit lost here at the moment but im thinking i left something unplugged, i have looked over every plug bunch of times. so i thought i list the part i put on and maybe we can get an idea if i installed one of these things wrong i would get this problem.
VRSF FMIC
FP Manifold
PR Rad.
Evo 560cc injectors
NKG 1g wires + plugs
Dual Catch Cans
SS oil feed
SS oil return
thanks for your support!
i did unhook a couple of sensors but i believe i have put them all back in there place. As for the injectors i have a 399 maf, i was told my A/F would be pretty dead on
I'd check the sensors you unhooked and make sure everythings tight. Also that's not going to be a sufficient "tuning" device. I'd throw your 450's back in and see if it fires up on those and put the 560's in when you have a real tuner.
yeah ill try the 450cc again tomorrow and see what happens, and i just corrected my firing order on my plugs... I can be such a dumba$$ sometimes..
