Car wont run
olmytsi
3,079
20
Jan 29, 2004
Miami, Florida
me and my buddy were relocating his air/fuel and boost gauge to the center vent and we had to cut the wires to run to the vent and then reconnect them to the gauges. after reconnecting everything, we connected the battery and started the car to make sure all the gauges were readin fine and the + and negative wires on the air/fuel gauge touched and caused the car to shut down. we started it back up but it took a few cranks and idled like shit...tried to give it a lil gas but it just died. We checked all the fuses out and now a friend of mine is suggesting that we burned the ecu cause the air fuel gauge is connected to it and we need a new ecu... i am also thinkin the car is not gettin any fuel ( does the fuel pump come on when the key is in the on position with the car not runing....if so its not turning on cause its a 255 and we couldnt hear it) the real question is What do you guys think? this is in a 92 laser awd by the way.
thanx for any help we need to get this car runnin asap.
make SURE all the wires are connected and solder them, then try starting it just a thought
Hrmm, you didn't touch anything in the engine bay? like the maf? If not, I would first check to see if you blew any fuses even though you disconnected the battery its possible that it still blew a fuse. If all your fuses are good I'd start looking into the ecu for problems.
all fuses are good so i guess i will be lookin for an ecu to swap...thanx for the input guys.
  • Wanted 6 bolt NT water pipe
    • chrisman287
