car will fire up but rpms shoot up.
sno_boarder4343
65
Sep 10, 2008
charlotte, North Carolina
Ok so i FINALY took care of all the other little problems with my car and gues what it finally fired up. it will run a little bit but then the rpms shoot up and i kill it before it red lines and i blow a gasket. When it fires up we have to use starting fluid because the gas is so old it just kind of sputters. what do you guys think the problem could be?
I would take off the intake Piping, and see if the throttle plate thingy in the intake is getting stuck.
Or, have a friend turn on the car, and see if the cable is being pulled.
Umm, Put some fuel stabalizer in the tank.
Clean the injectors. And Check the plugs.
