car sputters after manifold install
NycDSM11
65
Dec 5, 2009
new york, New York
the other day i replaced my exhaust manifold with a ported 2g. everything was great for the first two days had increased power and faster spool. the next day i started the car and had no power and it sputtered like crazy also i could not build boost and pass 40 miles an hour. so i re-torqued all the bolts but nothing. my boost gauge on my gauge cluster says i am doing 14psi when i tap the gas, the real gauge would say about 15 vac. i am running so rich and i even put a new gasket but no results. any input would be appreciated.
Did u do a boost leak test? Make sure everything is sitting settle. and did u remove anything else when u swapd manifolds. Like did u do anything else to the car to increase the performance.. when my j pipe was leaking i was going through the same problems
I have perfect vacumm it's 22
the problem was resolved. i fell like a total a hole since it was a darn coupler. i am a total idiot for not realizing the obvious :ohdamn: wow. thank you everyone you guys were right.
