Car running like crap with lots of codes
SBRGT-112g
Jul 15, 2004
Menomonee Falls, Wisconsin
Heres the thing I just did the works;turbo, injectore,fuel pump,FMIC,intake,safc2. every thing was going fine till about a week ago, i was waiting for my logger and I know that I was running rich then it started to run like crap. It wouldnt start, it ideled real bad and died some times, I wouldnt go when I hit the gas. I got the logger and checked the codes they were P0400=exhaust gas recirculation flow malufunction, P0196=engine oil temperature sencor range/performance, P03FF=I have know clue what this code is. Any way what could it be? I change the plugs. Could it be the EGR valve, Map sensor, ECU? I checked for a vaccum leak there was 1 going from my FPR to my boost controller I replaced that one and there is no leak there any more. and how do I do a leak test?
djsm1769 said:
take it to a local dsm shop or auto-repair place so u can get it fixed dont install stuff on your car if u dont know how to fix problems.
Don't be a dick. This is the problem diagnosis forum, so let's help him try and diagnose things. I don't know if you've noticed or not, but a lot of us here try and fix/solve things without getting reamed by a shop.
~that being said.
Even got you thread references. :cool:
P0400 - EGR flow fault. Did you block off the egr valve.? Possibly it is clogged which can happen on an higher mileage engine. http://www.dsmtuners.com/forums/showthread.php?t=133947&highlight=CEL+code
P0196 - Strange, my chiltons nor my haynes manual has a reference to this code.? You sure you have the right code down.? I can't even find a reference to it on dsmtuners.
P03FF - All I can find from searching is that hex #'s usually refer to internal electrical problems. Possibly a bad ECU?
http://www.dsmtuners.com/forums/showthread.php?t=148487&highlight=P03FF
[edit] I notice in your mod list that you have a walboro255, but no FPR listed.? If you don't have an FPR you need one, the 255 is overrunning your stock FPR. Problem right there.
turbotoad said:
:mad:
Go ahead, be a dick! The guy dicked me out of a set of fog lights! He received my money order for them on just about the same day he posted the thread. Guess that's were my money went..... :( He never sent the lights and has not responded to any of my attempts to contact him in the past few weeks. So go ahead, be a dick cause he certainly likes being one himself. :thumbdown
And if you continue acting like an ass, I'm sure a moderator would love to give you a one way ticket out of here.. Read the rules, NO VENDOR/SELLER COMPLAINTS. Take it to goodguybadguy.org or a similar vendor review site.. Post reported.
Exactly.
Not following these rules will get your thread closed. If the thread gets closed I really don't see you getting an answer to your questions other than a method called searching so please keep complaints OUT of this thread.
Fair Warning.
Have you figured out oyur problem? My car is acting the SAME way, and throwing the Same exact codes. let me know, thanks.
my car is running like shit after new head and timing kit. throwing same codes, was this solved.
