1G Car basically dead
jmackisback
52
May 14, 2004
Richmond,
I have fmic, wide band 02, correct ngk plugs gapped properly, turbo back exhaust,safc tuned. All has been well until today, but on the way to work i stopped at a light and when i went to accelerate there was almost zero power at all, like none. My autometer gauge showed normal boost but the car basically moved 5mph and my af gauge showed EXTREMELY rich, like 10 and it reeked like fuel. I checked for boost leaks and can't find any. Any ideas? No check engine light.
well if it reeks like fuel, and you are getting pig rich AFR readings from your WB, then id look at a failed FPR or injectors that are stuck open.
do you have a stock FPR and injectors? pull the plugs and see if they are soaked or you have fuel puddled on your pistons.
Yes i do have stock fpr and injectors. I will take your advice and check once i get it towed.
I will do a more thorough check today. Could a bad boost leak cause 9.5 AF and literally next to no power? When I say no power, I mean I can only reach 10mph
The stock AFR could be the issue as it is getting over run by the 255lph causing running rich and lack of power. Correct me if I'm wrong, but all the things I have read says you need after market AFR.
I have an AEM AFPR arriving tomorrow. I'll do a further investigation tomorrow as well, as I am stuck at work all day today.
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
