Beanokid69
- 358
- 0
- Oct 7, 2003
San Jose,
California
So my clutch fluid keeps draining and after some inspection i have found that it is leaking from the threaded bolt on the end of the clutch line (the bolt that threads into the piece that the eye bolt passes through.
I have replaced the clutch line which came with new thread bolts, replaced the copper washers on the eyes bolt, and used thread sealant tape on the culprit...STILL leaks... What can I do to stop this leak?
I can provide a picture if needed
who names these bolts) I didn't torque the banjo bolt to the new clutch line but it is on there as tight as I could get it and with threat tape around it...Also the only part that had washers was the banjo side, not the side that the line is on
