cant remove oil feed
dboyle23
297
16
Jun 10, 2010
Chicago, Illinois
So I am putting in a small 16g and am having issues with installing the oil feed. The part to the turbo is fine, but I cannot seem to get the bolt off from the old lower feed line to the oil filter housing. Anyone know the size of the bolt that is on the 2g oil filter housing? I have been trying to use 3/4 but it slides off and will not budge. Also, I tried to remove the allen headed bolt below the first one to tap in there for oil as well, that will also not budge, and I have the right allen head. It's frustrating.
Any tips?
I think I ended up using a MM on that because I just removed mine had issues using 3/4. Goodluck
Also, are you using 6 pt or 12 pt?
