Can't get a gauge to dim..
Smallfry311
52
Jan 23, 2009
Franklin, Tennessee
Well i just put in a gauge pod and a gauge from glowshift, and was wondering where the dimmer line hooks up to.. I hooked up the other wires to the back of the cigarette lighter and they work fine.
Where does the dimmer wire go??
Thanks.
If it's a standard "dimmer" action, then you connect that wire to the interior lights. Your gauge lighting will just drop down a notch or two when you turn on your lights. It's not variable like your cluster is.
