Can't boost past 15psi?!?
SleepingTsi94
261
Apr 24, 2006
Corn, Iowa
Well I can not get past 15 psi. I did boost leak test and fixed the leaks that I found. I have my mbc installed so the side nipple runs to the external wastegate bottom port. And the bottom of my mbc runs to the compressor housing. Not matter how far I turn the mbc in I still get 15 psi. I have a 9 psi spring in my external gate with 4 shims. Lots what should I check?
I would think that you could get a spring directly from Turbonetics. Is your BOV holding past 15 psi?
