Can the stock ECM handle an engine upgrade to the 2.2l Stroker and 10.5 piston?
TheGimp
May 6, 2005
McKinney, Texas
Like the the title says, will the stock computer handle an engine upgrade to 2.2l stroker and 10.5 pistons. I have the 420A engine ('95 eclipse) and I am considering the upgrade, but if I have to purchase a stand alone FMU I might reconsider. Also, what other upgrade would i need to make it work? Larger Fuel injectors? Larger Throttle body?
I don't see why you would have any problems running the stock ECU with the stroker and 10.5:1CR. Keep your headwork and cams on the mild side, and you shouldn't have any problems. You will have to step up to the expensive gas after such a build. No need to tell me how much it hurts. I know... :cry:
