Can I Run This Turbo Safe?
SleepingTsi94
261
Apr 24, 2006
Corn, Iowa
Well think my turbo is going out. And I have a friend who will sell me a turbonetics t3/t4 hybrid bb for $375 with only like 500 miles on it. Now my question is can I put this on and run anywhere from 10psi to 15psi and be just fine with out messing with my fuel system. I have 680cc injectors and a 255lph walbro sitting around just nothing to control them or tune with. So wondering if it would be safe to run it at boost levels and not over run the fuel system?
Depends on the size of the turbo, There are about 30 different combinations of turbo's that are T3/T4. Size depends on how much you can run with it.
Turbonetics SUPER-H Trim T04B compressor, .63 A/R stage 2 exhaust. Also would I need a oil restrictor to run a oil feed from the oil filter housing?
I saw you were runnin a 14b and just so you know, that T3/T4 wont bolt up to a stock manifold.
Id like to know about that oil restriction too.
You could run it but just make sure to hook the wastegate to the compressor housing so you only run wastegate pressure. Around 12lbs. That will be safe to run until you get proper fuel delivery and control.
KK I will have a electronic boost controller to control it. Also need to know about oil lines. Do I need a restrictor to run it from the oil filter housing? And if so what pressure should I be looking at idel and full throttle to be safe?
