Can I keep my 255 to swap to E85?
evileclipse909
392
4
Sep 17, 2007
Colorado Springs, Colorado
I've got a walbro 255 and an arimotive afpr. I'm gretting ready to get some 1000cc inj and wanted to also switch over to E85 at the same time. The only problem is that I keep geting mixed stories about being able to flow enough fuel to acomidate my 57trim turbo. Any thoughts?
Sounds like a delightful setup. I'm running 1050s a 255 high flow and an A1000 FPR. I'm running E85 with not a drop of knock on my 50 trim
you should be ok. what are you going to tune with and how much boost are you going to run? also your fuel pump may get maxed out. i would do a rewire. you may need to do a dual 255 setup to get what your looking for all dpends on you. I also have a 57 trim and am wating for e85 to come public. as soon as i do i will be geting 1000 injectors as well right now im running 780s if you do not want to do a dual fuel pump setup IF you get maxed out you could do a external but eaither way your going to need a -8an fuel line to support eaither
I'm on a 57 trim 1000 ccinjectrs and a wally 255hp. I'm at 97% IDC at 7500 RPM and 30 psi... that setup should be good to go for you but the pump is about maxed out right there. I'm going to dual pumps here as soon as i get finished buyilding my new line of dual pump hangars for 1 and 2 g cars.. If you'r einterested in a dual pump hangar i will have them ready by the ned of next week adn for a LOT cheaper than the ones you find on the net now days..(they retial for about 485 bucks...mine will be around 275 + shipping, and although not made of billet aluminum i garauntee they will be quality)
  • Wanted 6 bolt NT water pipe
    • chrisman287
