getusum
- 116
- 25
- Jul 23, 2006
birmingham,
Alabama
This is a newbie question but i'm getting fuel cut at 18 psi. If i buy a super afc 2 will this give me the ability to bypass the fuel cut.
MrBoxx said:Fuel cut is not a matter of not having enough fuel. It's a matter of the ECU/MAS seeing too much airflow.
Do a boost leak test.
getusum said:I mean hide the boost from the ecu! I dont have a boost leak And ive got a new 255 pump and injectors going in before the safcII. I understand why I get it Im just trying to run 30 psi. Im in the middle of a re-build and im learning as I go. I am building the internals to hold 30+ psi. Money I have-experiance I dont. please advise.
getusum said:Thank you for the link it answered my question. And i would never lean my car out to an unsafe AFR. Im buying an afcII to reduce the air count going past my GM MAF? correct?
98eclipseRS said:Uh....the ecu does not see boost once you install a boost controller because you don't use the boost seloniod anyway. Secondly what does boost have to do with you hitting fuel cut, fuel cut does not happen when you hit some magical number the ecu sees as too much, these are dsms not srt-4s with some retarded "stage" upgrade. I can garuntee you have a boost leak, as a matter of fact I am 110% sure you have a boost leak.
Secondly install an AFPR before you put the 255 in. It will overrun your stock fpr and cause tunnign nightmares, bad gas milleage, and will kill o2 sensors by you running obnoxisouly rich all the time. Then after putting int he above mentioned afpr put the safc in before the pump and injectros as well so you have a way of tunning out all the extra fuel that is trying to be forced into your engine now.
Why are you trying to run 30psi ont he stock turbo, not only will the turbo not make the much boost(you may spike to 30 but your not going to hold it) but it will be inneficient as all hell at those boost levels. You will do more harm by having a super high intake air temp than good by runnign that high of boost.
Just trying to save you some money here by why are you buying an afc if you already have a tunnign tool at your disposal? You can tune just fine with the gm maf/maf-t. Use the money you would spend on the afc and buy yourslef a wideband o2 gauge so you know what's going on with yoru engine.
Slow down a little bit do alot more research and pick a route you want to go before just throwign a heap pile of parts at your car hoping it makes more power.
getusum said:I went as far as taking off my fmic and putting in the bath tud while under 15 psi. My friend is a plumer and me made a cool tester for fmic and to fit my turbo for the first test. we were very careful. And I respect everyone on here for taking to time to answer questions from newbies like me I know it has to get old for you guys. Im very thankful. Im looking for a logger now, so any help on a user freindly one? Remember im from Alabama.
bluetlr2001 said:If you do DSMlink you will also need to get an eprom ecu.
Yes. For future reference, just because a thread is already up discussing a certain topic does not exempt you from using the search button.MrBoxx said:DSMLink. It's a logger, tuner, and diagnostic tool all in one. The product support is fantastic and the knowledge you gain from using it will be invaluable to you the more your car evolves.
