twitch231
- 0
- Jul 3, 2012
El Cajon,
California
alright somethings been going on with my 91 GSX for a while, making it barely drivable, under boost (evo III big 16 at 25 PSI) my car hesitates and runs rich at about 10 psi I'm 80% sure its a boost leak. I thought I found it at the throttle body gasket, so I replaced that and the elbow gasket in case it was there. I havent done a boost leak since but I did drive it, but with no luck in fixing the hesitating issue. last boost leak test showed a huge leak under intake plenum(sp?) where throttle body would meet. Which would be a gasket right? Or maybe a crack in my intake? I can't pinpoint let alone see exactly where the leak is just feel a rush of air. I've read something bout a shaft seal but I haven't looked into that, any help would be amazing, I live in el cajon if anyone can come take a look maybe you can spot something I can't. I am also willing to drive (not too far like 20 miles bad mpg because of leak) for someone to help me out maybe in the next couple weeks I could even pay some one to help.thanks.
Names Dillon you can contact me through text at 760-792-4537
Oh BTW don't think it matters but I'm pretty sure my thermostat is bad, shouldn't have caused this tho.
Maybe he could help you with your problems. I listed his profile. Good luck bro.
