can 420a crankwalk?
gijeff1805
Jan 26, 2004
conyers, Georgia
Okay after reading and looking forever i have to ask...i have a 1998 eclipse GS....and i was wondering about crankwalk in a 420a, does crankwalk mainly just have problems in the 4g63 cause thats all i seem to find in the crankwalk posts. and i am looking into engine rebuilt and possibly goin turbo latrer on with my 420a so will that change crankwalking any?
easily put do the 420a have problems with crankwalk like i read with 4g63? is it all 7 bolt or just 7 bolt 4g63?
420a's don't suffer from crankwalk =D muhahaha, just another thing that the 4g63 has that we don't.
Any motor can crankwalk. It just seems to be more popular with the 4g63's and even more popular with the seven bolts.
not more popular, it HAPPENS in the 4g's. ive never heard of a 420a EVER crankwalking.
That's right. Any motor with a crank and crank bearings can crankwalk. It's just extremely unlikely for most cars though. I only know of one design to have the problem (cough 7bolt cough), but I'm sure it has happened to other motors..... :dsm:
I've heard Miata engine suffer from the same plague as 4g63s
As said before, any motor can crankwalk. It all depends on the bearing clearences. This is why any time you build any motor, you must always measure crank end play to see if its in spec.
alright thanks, that helps me with deciding on what i was going to do, i was getting a little worried when i kept hearing all this about crankwalk.
Crankwalk in a 4g63 can happen but it's overrated. I don't want to rain on the 420a parade but I have heard of a 420a taking a walk.
Yep any car can have crankwalk !
I don't know if it is considered crankwalk but My rods bearing snaped out and screw my Crankshaft as well a rod. I just put a new motor on it.
I guess that: Been there and hate It! :thumbdown
Like AWDspoolin said. The 4g63 does suffer more than other cars. But it doesn't happen as often as some people say it does.
crankwalk is another symptom of premature crank wear. If you put a harmonic balancer on wrong you can get crankwalk.
Well as far as crankwalking....you really should not worry about it in a 420a
YOU SHOULD worry about spun bearings due to the infamous long right hand turn oil starvation problem.... i personally spun a bearing badly....enough to merit the crank be reworked and oversize (ewww) bearing need to be used...
Solution to this? easy make yourself a baffled oil pan
And i thought there was a fix for stoping CW on 7 bolt blocks?? wasent it all the oil squirters fault? ( according to Magnus CW theory?)
Well, that's just their theory. There are also about 8 other good theorys. Until one of those theorys becomes fact, there will be no fix for crankwalk.
That's not true, we just won't know which fix is the one that works until then :D
99gst_racer said:
Dude this is the same thing I'm saying. Once we find a fix, it will turn one of those theorys to fact.
You should sell it ad buy a non turbo. (Sorry, couldn't resist and thought everyone might like a good laugh.) :D
hahahah I just got off the floor, man about time,it's about time :thumb: :laugh: :laugh:
LOLlerwo0t! amen to that! :thumb:
420a's will not crankwalk. period. They *could*, but they will not. end of story.
The only 2 eclipses I have owned (95 GST and 95 GSX) have crankwalked... So in came the 4g63 (6 bolt). They have the same chances to crankwalk as pretty much any engine out there.
j_eclipse96 said:
My 420a in my RS crankwalked at about 100k miles. I can't confirm this, but thats what the person who had it before me said.
I think the person who had it before you was a retard. I have never heard of a 420a crankwalking, however this does not mean it cannot happen.
Speaking of crankwalk, does anyone know what other cars have cw'd? I have heard it is common amount miata's as well...
  • For sale 2g 2G AWD Fuel Level Wiring Harness
    2G AWD Fuel Level Wiring Harness $35 + shipping and paypal fees* removed from 97 TSI AWD * all...
  • For sale 2g 2G OEM Passenger Door Handle
    2G OEM Passenger Door Handle $25 + shipping and paypal fees* the seal and two mounting bolts...
  • For sale 2g 2G OEM Interior Silencer Pads
    2G OEM Silencer Pads $20 + shipping and paypal fees* these go behind the plastics to the left...
  • For sale 1g 90 Oil Cooler
    90 OEM oil cooler with custom lines. Takes 18x1.50 mm fittings at the housing. Fits in a...
  • Wanted 2g 2G FWD Fuel Filler Rubber Hose
    Decent condition FWD fuel filler hose.
    • kyler021
