Camber
Talon2z
73
Feb 28, 2004
Richmond, Virginia
I am going with the tokico shocks and springs which I believe is a 1.5 inch drop for the FWD. Does anyone know what camber kit will be needed for this setup? Will I need more than a 1.75 degree correction?
With an even drop you will probably be around -2° in the front and -3.5° rear. Depending on what you do with your car you can probably live with the front but you will need some spacers in the back.
