camber kit bolts and install help.
spawn87
908
3
Dec 6, 2007
sacramento, California
so i just got my camber kit in and everything seems ready to go both front and back but for the back i notice it didnt come with longer bolts to compensate for the washers so my question is:
how much longer do i need the bolts and are they m10 - 1.25?
and does someone have a DIY or link to how to install it? i wana do it my self before taking it in for alignment and how do i check for the right amount of correction?
what kind of lowering kit you put on? How much of a drop is it? Someone might already have done the guess work for you. Just post what kit/drop you got along with the type of alignment kit(s).
I got a tokico set up with about a 2in drop. Ingalls kits all around. i believed i used 3 washers per bolt on the rear and I got the adjustable ballm joints on the front.
I don't think that would work since there are many washers out there that are different sizes. If I remember right my car isn't even dropped 2" and needed 4 washers. Its just trial and error.
