Cam Gear to HKS Cam Torque
High PSI
145
17
Oct 21, 2004
USA, Australia
Reeeaalll quick question. I'm dropping in HKS 262's. I've read through the VFAQ but it doesn't say what you torque the stock cam gears to when bolting them to the cams. Anyone have this info?
I know, I need a service manual. OMG
What do you torque the bolts that hold the intake manifold to the head to?
In case you're wondering, I'm rebuilding the engine after having the timing belt go. I've got the torque specs for everything else, just need it for these two items. PLEASE HELP! Thanks!
From the manual; the stock cam gears torque is 80-100 Nm or 58-72 ft.lbs.
and Intake to Head torque is 30-42 Nm or 22-30 ft.lbs.
Good luck :thumb:
