Antiqueford
- 0
- Feb 12, 2010
Grantsburg,
Wisconsin
It's getting too expensive to drive a v8 everywhere, so I'm looking at a 1995 eclipse rs with a 420a and a 5-spd. It has some unknown engine issues and doesn't run, but the body and interior are clean.
I'm guessing that some timing problems are causing the issue, since spinning a cam sprocket or jumping teeth seem to be common in these engines. Also the craigslist posting says it didn't have any oil in it when they got it.
So I'm going to assume that we have a block with bad mains, scored cylinder walls, and rings made of slag, and a head with two free spinning cam gears, a broken timing belt, and 16 pretzel-shaped valves.
The price tag is $895
A friend of mine has a complete and good short block sitting around (uncovered, however) for the past few years, and a matching head with a bad exhaust cam. The casting itself is in good condition, as well as the intake side of things. These parts I can get for $50
Craigslist has plenty of postings with used cams in good condition around $50, valves are about $10 a piece, and the parts store has everything else I will need. what I'm trying to do is prepare for any and all surprises (as if that's possible).
What should I look for when I go look at this thing tomorrow? Are there any common pitfalls that a DSM noob like me is gonna fall into when I dig into this project?
Since its costing me about $2,000,000 a week to put gas in my truck, I wanna have this thing on the road asap, any suggestions and advice will be greatly appreciated.
