By Passing the Fog light Switch?
87grandnational
Sep 28, 2005
Scott City, Missouri
Is there anyway to by pass the fog light switch so you can turn your fog lights on without having the head lights on? Like the S/C Cobras.
I would like to run the Amber Parking lights, and Fog lights w/o the Head lights. Around Dusk.
I used this guide on VFaq:
http://www.vfaq.com/mods/2G_foglights.html
And here are the results. You can also just have the foglights on alone if you want. Read at the bottom of the link, it tells you how to wire it thru the radio relay, so that the fog light switch works any time, as long as the key is in. So if you forget and leave them on, when you take the key out they turn off. Works great and its easy to do.
I followed the instructions above to have the switch work all the time with the key in. Only insted of fog lights it works on my angel eyes!!!:rocks:
p.s. they warn you that doing that may cause the fuse to blow with aftermarket radio's with large internal amps but mine is wired strait to the battery so i don't have to worry about it anyway.
2G Fog Lights with Parking Lights
How did you make your corner lights so bright??
Probably LED's or something or just the picture. I put LED's in mine along with the reverse lights, etc. I like little details like that hah
