Buzzing Noise From Intake Manifold
Meh987
182
Oct 14, 2003
Carmel, Maine
I went to the track yesterday. After one of my first few runs, when slowing down, I heard a wierd buzzing noise coming from my engine. I checked and it seems to be coming from or under the intake manifold. I don't ususally hear it when I'm driving. Ususally I will hear it when letting off the throttle or at idle. It hasn't affected the performance of the car, just an annoying sound. So does anyone know what's wrong?
I have just noticed that the sound speeds up when the engine revs up. The best way to describe the sound would be like something rubbing against a belt. Also, if you push down on the intake manifold, the sound goes away.
you might have a vacuum leak .. i ended up changing the intake manifold gasket .. but on the other hand it woud effect the performance of your car .... do you have idle surge ? if you its most likely that u have a vacuum leak
Nope, no idle surge. I'll check for any vacuum leaks in the morning. Do you think theres anyway it could be transmission-related? It's now only happening when I go in reverse, or when I let off the throttle while I'm in gear.
I finally figured out the problem. I noticed that my A/C belt had split in half and was lightly shredded. So, I took the A/C belt off, and the sound was gone. It turns out there was a plastic shield that had been pushed up towards the A/C compressor, really close to where the belt was. The belt had been rubbing against that plastic and making the noise. I pryed it out the way, put a new belt on, and the sound was gone. :thumb:
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
