Buschur UICP clearance issues between BOV & ABS?
HokieDSM
1,725
Oct 24, 2002
Blacksburg, Virginia
Hey all -
I'm wondering if this problem is unique to me, or everyone who has a Buschur Upper IC pipe & ABS. Anyhow, a few weeks ago I had to reconnect my BOV recirc tube and because of the way that the UICP mounts the BOV almost directly into the ABS unit I could barely fit the tube in - I actually had to scrape the tube by the ABS unit to make it fit.
The recirc tube was already old and a little dried out, and a week later I found that the tube had actually torn open from the stress of being so close to the ABS - this seems like a design flaw in the UICP - or is something wrong with my setup? I'm having a bi*** of a time trying to find a replacement for the recirc tube - no one sells rubber tubing with an inner diameter of 1 1/8" - so I've had to go with some white plastic accordian tubing I found at Lowes - but I'm having trouble making it fit because of the ABS being in the way.
Can anyone else out there verify these clearence issues? (Image attached to show how close they are)
I can't really help you, but I know that Dejon makes the 1G ABS equipped car's UIP 2.25" compared to 2.5" for that exact reason.
I don't understand why they just didn't put the BOV flange somewhere else where it wouldn't interfere with the ABS...
Anyone else? I'm really tryin to work this out. The wierd thing is I don't remember it being this bad before...
  • Wanted 6 bolt NT water pipe
    • chrisman287
