Burnt wiring need help.
teamitr
100
Jun 14, 2005
Riverside, California
I Just purchased a 95 gsx and noticed that the three wires from the speed sensor are melted so I went ahead and cut them were they where not melted any more. so I go to start the car after fixing some little stuff and the car turns on but runs stupid rich so I hook it up to the scanner and noticed i'm not getting any signal from the maf sensor which i tried swaping and checking the harness plug which everything looked fine. Also the tps sensor gives me 100% open signal AT ALL TIMES and if i unplug it it goes to 0% I also tried swaping it for a known good one. and I also checked the plug harness for melting. I also swapped the ecu for a know good one and the same thing. The only thing that i can think off is to check the complete harness for more melting points. But is there anything else that i can look for? Like relays besides the ones on the fuse box and fuses.
If I were you, I'd pickup a full wiring harness from a local boneyard or Gary at mitsubishigraveyard.com and start over as there's no telling what else you'll find wrong with the known bad wiring and inspecting every inch is not going to be fun :dsm:
