jed344
Supporting VIP
- 1,515
- 563
- Jan 10, 2008
Waterville,
Iowa
I am finally going to build my motor this winter. I have one question I will be using Manley 156mm h beam rods with most likely a wiesco stroker piston. I know this will lower my compression below the advertised comp ratio on the piston. This is a 90% of time e85 car. Should I try to run. A 10:1 piston or any thoughts on Similar builds? I figure a 10:1 in my car will be low 9s on compression. I also see Manley makes a piston for a Dsm with a 88mm crank and 156mm rod should I just run that piston instead of a stroker piston?
