Brought a 99 4G63 block, Can it still be used.
shaunp
115
4
Mar 11, 2008
Snellville, Georgia
I recently purchased a 1999 4G63 block from a memeber on this forum, I was assured the block had no damage to it. When I took the block apart today this is what I found. I need to know if this block can still be used or if I'm out $125 bucks?
Did that thing break a rod or what? You would probably want to have that checked for cracks where the gouge is at in the block.
The crank needs to be checked out, a grind will be in order if that rod throw in the pic is not too bad.
Block may need to be bored also, depending on the gouges in it.
