Broken clutch bolt
jdblood202
70
9
May 18, 2013
Hampton, Virginia
Hey guys, have a quick question. I'm doing a clutch job on my 1990 gs turbo. I found one of the clutch bolts broken off in the block with no part of it sticking out. What would be some recommendations of getting it out? Just drill it out and re-tap the hole? Just looking for some ideas. Thanks guys for the help!!
You have to take it to machine shop anyway. Have them extract it. All else fails get another flywheel.
There is not 1g or 2g flywheel. There are 6 bolt and 7 bolt. Of those two there are FWD and AWD so that is four possibilities. Buy whichever is appropriate if you go that route.
My 2 cents. I am not a fan of lightened flywheels. Might be fine on a racetrack but I don't care for their behavior on a street car. Street cars slow down, stop, idle etc. Driveability in traffic suffers in my opinion. Take that for what its worth.
I had to do that once i used a drill and easy out then used a new bolt to put in it. Holds up just fine. Just be careful when you do it take your time .
Use a left hand drill instead of the normal right hand drills & it will be easier (& you might not end up not needing an easy out).
*Left-handed drill bit*
^ You mean like this-
Precision Twist Drill - 3/16 Inch, 118 Degree Point Angle, Bright Finish, High Speed Steel Jobber Drill
General Purpose, Standard Point, Regular Spiral, 3-1/2 Inch Overall Length, Left Hand, Series L10
Mfr Part #: 010912
MSC Part #: 78505302
Write the first review
See more Jobber Length Drill Bits ►
List Price with
Your Savings
$6.81 ea. $4.90 ea. $1.91 ea.
Qty:
$4.90
Item Notes
773 in stock
73 available to ship from Reno, NV
Hassle Free Guarantee
We'll exchange or refund any product that doesn't meet your expectations.
Likewise for me. I assume you noticed the "left hand" reference in the manufacturer's description too. People are left & right handed. Threads & tools are left or right hand.
Thanks for the suggestions guys. I ended up getting it out, used some heat and an easy out. I would have had the machine shop just do it, but I'm strapped on cash and only had enough to get the flywheel resurfaced. I've just never even messed with removing broken bolts before, really wasn't all that bad, just had to keep a steady hand. Thanks guys!
