1G Brembo compatibility
bigplans1g
Sep 19, 2011
seattle, Washington
I have a set of Brembos from a Trackhawk available for a killer price. I know a mounting bracket and rotors will also be necessary but I'm curious about weather or not anyone has used those ones specifically in their DSM?
I apologize if this has already been discussed. I did a quick search and found nothing with those specifics. Do most Brembos have the same mounting bolt pattern? Does anyone have firsthand knowledge that this is as easy to do as an Evo Brembo swap?
I appreciate the information and help fellas!
No, There are quite a few different mounting styles and spacing since Brembo makes all sorts of calipers for different companies Some have integral mounting ears and others use brackets. Even the ones with mounting ears differ to match the car's mounting points and rotor centerlines.
