brand new tranny grind
Double check clutch disengagement. Put it in gear. Depress clutch and try to start. If it bucks while trying to start you will need to check over the entire clutch system
Adjust the rod (its above the gas peddle ) I just had this same problem after about an 30mins of adjusting , It garbed every gear easy ..Make sure to bleed it , then bleed it some more , then bleed it again , then bleed it just to make sure (also make sure to top the fluid up)
He may have been stating the same thing, but check for clutch drag. It will screw up shifting as it will never really disengage the clutch. This will put stress on the syncros or prevent shifting altogether.
Have you checked the clutch bearing in the pedal assembly? If that is worn all the adjustments in the world are not going to help. Bleed your clutch, adjust your clutch pedal, and if still not working, I would assume its the pedal assembly itself.
his clutch pedal is squeaky and im pretty sure its leaking fluid a little bit
