Brake upgrade: Master Cylinder
turbodsm_125
145
Nov 14, 2007
Dayton, Ohio
i have a 90' eclipse with dual piston calipers on the front off a 94' eclipse. My master cylinder went out yeasterday and i was wondering if the master cylinder off of a 94' eclipse or n/t 3000gt would work and if they are better. i.e. push more fluid. as they come with bigger brakes from the factory.
Pushing more fluid will only affect pedal travel, a larger booster would give you a softer pedal and more potential pressure, but these are not limiting factors in brake systems- leverage and contact surface area are more important
