brake upgrade and proportioning valve ?s
slider85
469
May 21, 2004
Langley,
most likely next spring or summer I will be upgrading my braking system. First off, does anyone know the stock front/rear braking %'s, like 70/30 or 60/40? If I upgrade to larger rotors and two-piston calipers in the front, can I get a different proportioning valve to bring the split down close to 50/50 or 60/40? I have done some searches and found that some of the AWD guys have switched from 1GA valves to 1GB valves because they are different, can I do that on my car? if this is unclear I will clarify later.
p.s. I plan to upgrade to the stock two-piston calipers with slotted rotors all around. i already have the ss lines installed. or if I have the money I may go to the Baer brake upgrade.
