brake pads 90-98???
That's the right set for a '93 Talon. 1994-1999 awd Talon uses DP2954.
wret, just double checking, you did read my post right, where i have dual piston calipers, i was under the impression that the single piston calipers had smaller pads?
And you're right because the rotors are of different size. 90-92.5 are different from 92.5+.
thats what i thought, so im guessing that these pads on ebay are really for 90-92.5, the seller is just unfamiliar with the different specs for the AWD dsms???
Agreed, all FWD have singles. I wouldn't take the chance if the seller is unsure.
