Brake line issue
wilddog
119
Feb 20, 2006
Montana
I replaced all my pads and rotors this week, but also disconnected the calipers from the brake lines to buff all the rust off of them. I reconnected all the calipers to the lines today except for the rear left caliper. When I try and twist the brake line into the caliper, the line just spins around. Its as if the thread in the caliper and the thread in the line are not mating and locking together. Rather just spinning around and around. I tried cleaning the both threads but still the same problem. Any one run into this issue and solve it? What are my options? Cheers
tap it with a hammer lightly and try screwing it in. Taping it in should help it grab and allow you to screw it in. Tap and Screw. Tap and Screw. :wink:
Try pushing on the nut with an open end wrench (around the line) while screwing it in with another wrench. Push hard but make sure the nut goes in straight (which is why to use open end wrench for equal pressure on both sides of nut). With that fine thread it's easy to get it cross threaded.
So I took a closer look at the fitting on the brake line, and I dont know what to say. For some unexplainable reason, the fitting on the line is completely smooth and then suddenly has the last 3 threads on it. Its as if all the threads have been mashed and smoothed down. But you cant faintly see the threads. My woman took my digicamera on her trip so heres a ppor mspaint drawing. I have no idea whats going on. Can anyone give an explanation, or what my next step should be? Cheers
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
