Brake line fittings
TSITurbo95
18
Oct 26, 2009
Ohio, Ohio
So I am in the process of deleting my ABS, and am using hydraulic hose, and need the size fittings for the brake lines and proportioning valve. Thanks.
Did you check out the STM kit? Comes with everything needed.
that totally answers his question! LOL
the fitting size is m10 x 1.0, the fitting also needs to be flare so it mates with the flare in the portioning valve. If you are using hydraulic hosing for the brake line, -3an would be sufficient size.
Not worth $250
Just what I was looking for, thanks!
Now are the master cylinder threads the same?
It would be much cheaper and more reliable to just use metal brake lines and bend them yourself.
