Brake Lights won't turn off
Yaeger28
Oct 6, 2011
fort bragg, North Carolina
Just like the title says. I pulled the fuse and they're off now but I have no idea what the problem is. Help please. Ihave a 98 gst
Sounds like the brake light switch which is located under the steering colum and is above the brake peddle. I would check to insure it is working but you may just need to replace it.
There is a rubber pad that contacts the brake switch to turn off/on the brake lights sounds to me like its gone, i take electrical tape and wrap it around the hole several times and it fixes the problem.
when it happened to me.. it was that little rubber piece.. I put a zip tie in the hole and tighten it up and it work.
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
    • Detail
    • dsmmario
