Brake lights out Help!
doobycareful
90
Oct 4, 2006
East Highland, Michigan
My break lights don't work the only one that works is the one in the middle on the spoiler, checked all the fuses the bulbs themselfs they seem fine, i really dont know where alse i can look, I'm a dummy when it comes to electrical wiring :notgood: so any help will be appreciated. I've searched but with no luck so far :cry:
Get a voltmeter, see if you have power to the bulbs.
Check your grounds, make sure they have a good connection.
That should help you get started.
On the intake manifold there is a ground wire if it is loose or off, your brake lights will stay always on or off. Very quick place to check.
Pull the relay and see if it smells burnt.
