Bov help
j_biggz
287
3
Feb 6, 2011
Vancouver, Washington
So right now I have a BOV that vents 100% atmosphere an have been told it is making my car run rich between shifts due to the MAF. I wanted to know if there is a bov that I can use but not have my plugs fouling out either. I do like hearing the bov whistle. Any ideas?:confused:
Switch to a gm maf, the translator should have a setting for it. Or you can switch to speed density. Otherwise you should recirc it back to your intake.
you need your bov to recirculate. If you have dsmlink with speed density or a gm maf then you can run to atmosphere.
Junk yard, ebay, craigslist. Take ## pick. Once you have that you need a maf translator.
That is what you need as well and a gm Maf to go with it. I got mine from a junk yard for 30 dollars.if you cant find one, you can find them at cimotorsports.net
So the translator an a new maf an then I can use my 100% atmo BOV? Will I notice a difference or will it just stop fouling? Do I need to do any tuning an all this other stuff I am reading? Is there another bov I can use besides stock while I am waiting?
