98spydert
- 1,916
- 9
- Jan 16, 2004
Phoenix,
Arizona
Do any other blow off valves share the same flange as Greddy's typs s, rs, r? Or are there any similar that wouldn't take much modifying like cutting and rewelding. Thanks-
98spydert said:If you're going from a 1G to a type S. I don't think they're reversable. I wouldn't use the 1G anywas, it can't hold the boost I'm running.
98spydert said:I'll probably just try the type RS since it'll bolt on with no modifying and it's supposed to be a pretty good valve and better than the Type S.
A Greddy Type R bov uses the same flange as a HKS Type I Racing Valve.kraka said:I don't believe that any other BOV shares the same flange with the Greddy line...Well, except the 1G minus two holes but I doubt if you are upgrading from a Greddy you will downgrade to a 1G...What BOV are you thinking of getting if any?
