Borg Warner s259 question
xezerax
166
Feb 4, 2006
sayville, New York
Ok so I am playing on upgrading from my td05 pte5557 this winter and I pretty much have my mind set on the s259 extended tip. My plan was to switch over to a t3 setup and I already have a manifold/ 4bolt o2 housing picked out for the setup.
But when looking at the different turbine housings I noticed their "4 bolt" outlet is a .55 a/r, the same as their td05 housing. Am I going to benefit much from switching to a t3 setup when I could have a .55 a/r td05 housing and keep my current manifold?
Or should I just go for the .70 a/r v-band outlet and worry about fabbing up an o2 housing when the time comes?
My plans are to make at least 500whp with meth and race fuel if I have to, and low to mid 11's :hellyeah:
Heres the info on the turbo..
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Bullseye Power S259 Turbocharger Extended Tip
If you're using a T3 flange you won't want anything but the .70 a/r V-band housing to support proper turbine flow.
I'm not saying the .55 housing isn't capable....Wendy's car made almost 550whp with the S259 in a .55 DSM bolt-on turbine housing.
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/7PUPoBDI4P4?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/7PUPoBDI4P4?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
