boost, then stall.
bowens1414
123
Oct 30, 2012
Bradenton, Florida
ok on the way home i seemed to get my mbc situated but once i was about a 1/4 mile from my house i did a second gear pull to notice i was back at 5psi of boost after i did that i kept the clutch in for a moment and the car died so out of curiosity i replayed the even to see if it was a fluke. no fluke same thing happened this is a 97 gst person before me did an emissions delete along with the stock boost controller. so ive been trying to just get back to stock levels and i finally do for a bit. then this happens. so if anyone has an idea help would be greatly appreciated.
Recirculate your bov, that might be your problem right there. The tune/ecu shouldnt have anything to do with this problem.
ok and this MBC problem is pissing me off. yes it works fine but not in the car. my boost is weird its not normal where it spools around 3-4k and slowly lowers as rpms rise. it will quickly creep as if the WG flapper will not open. but other times i cant get over 5psi with the MBC in the same position leading me to believe that the flapper is sometimes stuck open a little bit. with this stalling problem new im not sure if the WG has a link to the problem but seems like it could.
