Boost leak fix and EGT temps
joejoe13
43
7
Jul 11, 2011
Kittanning, Pennsylvania
I have a quick question for everyone. I built a boost leak tester and found I had injector seal leaks on all 4 lower seals and throttle body and a few other places and replaced all clamps with tbolt ones. I was runnig right around 10-11 psi before I replaced all seals including the intake seal. I put everything back on and tried to make sure nothing was turned or anything since I had to disconnect the wastegate from the turbo to fit on the tester. I had to move the MBC as well but never turned anything. Now I am running 16lbs. It is a 20g turbo on the car as well. My question would be would the leaks be so bad that it would only spool to 10 and now since fixed 16? :confused:
The other question I have is how do you monitor EGT values. Can you do it thru dsmlink or do I need a gauge as well?
If you had enough leaks before your gauge its very well possible that it was always at 16# but the pressure was lost through leaks.
EGT while good for specific applications, you would get more useful information from a good wideband like the Innovate MXT-L.
I have a Aem WB but I am new to tuning my car and I always see people talking about EGT, knock, and A/F
EGT is really needed for High horsepower applications. The WB will be more than enough to use for tuning purposes and fuel/air mixture. Too lean/Too Rich = Too hot.
