Boost Leak/Blown Valve?
esoung
80
Jun 17, 2006
CA, California
The situation is that when I run the car there is no boost, wideband runs all over the place no matter what the setting are on my SAFC and the car died downs while I'm driving anywhere from 20-35 mph.
I definitely have a major boost leak. Using a boost leak tester I cannot put any air pressure in and I cannot find where the boost leak is.
Could it be a blown head gasket or valve? I mean the is no air pressure at the throttle body or does the head gasket or valve have nothing to do with a boost leak test?
If you have a boost leak THAT bad then you should be able to hear where its coming from. Get a spray bottle with some water and spray it across the intercooler piping and the couplers.
I tried that but I cannot find any leaks I think it leaking somewhere in the head. I'm not getting any air pressure from the intake manifold/throttle body.
So with could be the possibility of a boost if I cannot find the leak and there isn't any air flow before the throttle body?
All you have to do is put your tester on the turbo inlet, or begining of pipes, which ever. pull the piping from the throttle body elbow, and grab something to seal it off (I had a friend hold a rubber block over the end, it worked) and pressurize it with the piping being the only thing tested. If you cant pressurize JUST the pipes, make it smaller, test the FMIC alone, test both sides of the pipe seperately, etc.
If you dont get a leak with the pipes alone, leave them out of the loop and put your boost leak tester directly onto the throttle body elbow, and try from there.
And yes, it can leak into the cylinders, rotate the engine to cyl 1 TDC, and make sure you cap the vacuum lines that go into the intake piping.
Did you try the boost leak test at the throttle body? put the engine at 30*ATDC on#1, and pressurize the engine and post back. I might have misunderstood you, but did you say you dont even have pressure at the upper intercooler pipe?
What's 30*ATDC?
Okay, when I switch from electronic boost control to mbc I double looped the air flow so the wastgate was always open.
Beside that I can hold 15 psi on the boost leak tester. There are some minor leaks but when I start the car it still has no boost and is runs really lean all the time no matter what the SAFC setting are. I figured that if the boost leak is after the MAF at the turbo compressed outlet coupler I wouldn't be lean right?
