boost gauge ?
91dsmeclipse
181
Mar 22, 2004
Siloam Springs, Arkansas
i just bought a boost gauge and it came with this little tiny hard vac line how do i put that in a t fitting i just cant figure it out?
i had the same problem when i got mine, but i rigged up something with a tiny bit bigger more flexible hose i streched the ends of it over the vac line and secured it with a super tight zip tie (maybe throw in something liek silicone to seal it) and stretched the other end of the softer hose over the T splitter and voila! it worked great.
if u want pix lemme kno i can take some but mine is on the intake fuel solenoid nipple cuz its a 2g
first of all, is this boost gauge going on your n/t? if so then I cannot answer your questions because there is no reason to put a boost gauge on a n/t car
Don't use the hard plastic lines that come with the gauge their useless. Get some silicone vacuum hose, a small T fitting (to tap into pressure/vac line) and a 1/8" npt barberd brass fitting (to connect to gauge) & u'll be set.
  • Wanted 6 bolt NT water pipe
    • chrisman287
