lordnikon_04
- 230
- 0
- Jul 15, 2004
Goodyear,
Arizona
Ok, I just baught and installed an Autometer Meter Boost Gauge in my TSI AWD. Now i followed the VFAQ to install the boost gauge. i did everything right as i can tell. I tapped the line going to the fps that went to the middle of the intake manifold(just cut the stock line and used the supplied t-fitting), ran the supplied tubing through my steering boot, up and behind the dash, through where the dash speaker sits, and then up through my A-Pillar. Now when i start the car, rev it, and even drive, it doesn't read at all(well sometimes the needle will move but u can barely tell). is there something i messed up with the tubing? can that tubing be pinched enough to cause this? or do i maybe have a f'd up gauge? also, how tight should the adapter on the back of the gauge and the compression on the back of the gauge be? the instructions say don't overtighten them but do i just hand-tighten or wrench it to a certain torque?
