General Boost Controller
spyderdrifter
5,432
862
Jul 11, 2009
Somewhere in, Colorado
I'm not really sure if this should go here, but it sorta makes sense to me. I just bought Ace Hardware parts to build my own manual boost controller based on this diagram...
My parts...
How can I determine how much to shorten my compression spring? I don't want to cut it too much and then make it worthless. Only bought one, should have thought about that and bought several. Same question for the bolt.
Thanks.
Personally I'd have done a straight fitting and tap for the wastegate nipple, instead of a 90* fitting. Aside from that, the bolt can be as long as you want, the springs I'd set up a crude spring pressure tester with a gram scale and find length/pressure that works for you. Or buy more springs and experiment.
This is another reason why a straight fitting tapped for another npt fitting would be nicer, so you can utilize the longer spring and bolt to its full potential.
Edit: also, they have the one port labeled as going to the bov, when it should go to the charge pipe directly, either at the compressor cover or j-pipe etc.
