boost controller help
Not sure what you're asking. Did the eBay one not work? If it did, there's no reason to take it off. If it didn't, then I would suggest a hallman boost controller. Great little things, and fairly cheap too.
If there wasn't a problem with the ebay controller and you have an aftermarket boost gauge, I'd use the controller until you can get a name brand and watch your boost incase the spring decides to give out and you blow past your boost setting and do some damage.
ok a manual boost controller is pretty much just a valve, so and ebay one will work just fine. And if it was not working properly look into buying a decent one. You dont need to go spend hundreds of dollars on a name brand mbc. they all pretty much work the same.
If you have full dsmlink v3, you can control boost through that, as well as being able to control boost through gears. Save money and buy something useful. Maybe some additional maintenance?
