bogging? help
Daaan
229
Aug 15, 2007
Courtice,
I fired up my 92 talon after rebuilding the head, and starts great. the only problem is when i give it some gas it boggs :confused: but if i hold the gas down it will stop bogging and rev normal. could this be the cam timing sensor?i had to take it off and may have mis-set it.
how can i fix this?
spray some intake spray on your mafs .. hows idle? any codes?
idles great only when i give it some gas it will bogg.
could it be the timing? all the marks lined up, except the cams, when i put a ruler across them the first 3 lined up and the one at the end was about 4mm off. i thought this was because of the tension. but all the other marks lined up perfect.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
