BlueTurboSpyder
- 138
- 6
- Oct 26, 2005
Halifax,
Pennsylvania
Lately, Ive noticed my car spits out a puff of blue smoke (oil) followed by black (fuel) when I rev it up in neutral. It usually happens when I rev it past 5000 rpms and thats the only time. It wont do it while I'm driving or at idle. I've done a compression test and the results were 161, 165, 167, and 169 across the board. I've also checked my turbo for excessive shaft-play and only found a little side to side play NOT in and out. I pulled my lower intercooler pipe and found very little to no oil residue. After that, I took off my PVC valve and found that it needs replaced. I could blow through both ends. Could this be the cause of the puff of blue smoke somehow? The only thing I haven't done is a leakdown to check if the problem is caused by a bad valve seal. But, I was under the impression it wouldn't be necessary given that my compression numbers are way above the service limit and they are not more than 15 psi apart. Can someone give me some input? Thanx.
