BLT weird clicking
TSiTalonawd96
97
Jan 9, 2010
Lynchburg, Virginia
As the title states i'm getting a weird clicking noise coming from what sounds the charcoal canister when doing a BLT. It also sounds like its hissing down there(leak). Can I just bypass the canister or is it a must to have it?
^^Haha I didn't even think about that when I typed it.
You know I was just looking... can't you cap off P E and A on the throttle body? All 3 of them are just going into solenoids then to the EGR and charcoal canister... I've heard the P is for pressure regulator for the fuel... is this correct?
Yes you can. If you don't have to worry about emissions then go ahead and do it. The only thing you'll gain from it is less sources for boost leaks. You won't gain any power from it. I attached a diagram of what the engine bay should look like if you remove them.
